February 12, 2022 at 2:39 pm
ansys_noob
SubscriberHello, good day.
I'm simulating a wind turbine, I designed on my own, using ANSYS FLUENT. At tip speed ratio equal to 5 and lower, I'm getting positive torque. However, at tip speed ratio equal to 6 and above, I'm getting negative torque. Since I have frame motion enabled, the wind turbine is "still spinning in the correct direction" but if this was in the real world, I think, negative torque would that the wind turbine is spinning in the opposite direction. What does this mean? Which is the problem; my simulation or design?
February 14, 2022 at 12:14 pmRob
Forum ModeratorIt could also mean the blade is spinning too quickly for the air flow. Have a look at the local flow field, has the tip stalled?
February 14, 2022 at 2:22 pmFebruary 14, 2022 at 3:00 pmFebruary 14, 2022 at 4:10 pmansys_noob
Subscriberthank you
Viewing 4 reply threads- The topic ‘Negative torque at high tip speed ratio’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3967
1431
1272
1119
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
