September 10, 2022 at 10:12 am
tumulpurwar
SubscriberI just want to be confirmed, Negative load multiplier in Ansys means Tension?
September 10, 2022 at 11:38 am
peteroznewman
SubscriberNegative load multiplier means the structure would buckle when the applied load is in the opposite direction.
If your applied load was to compress the structure, then yes the opposite direction is tension.
September 10, 2022 at 11:51 am
tumulpurwar
SubscriberThanks Peter
- The topic ‘Negative load multiplier buckling’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1487
1318
1156
