July 14, 2023 at 9:31 am
ekayar01
SubscriberCan you please advice me any further steps to overcome negative Jacobian fail? The following steps were tried to handle.
The soft body impact FE model configured using SPH impactor and shell (UD facing and backing skins) & solid (honeycomb core) elements of a wing. The UD elements are formed using *MAT54/55 (Enhanced damage).
- ELFORM changed to reduce integration. Shell element formulation is converted to 2 from 16 to reduce number of integration points when I got the negative Jacobian fail (The termination rows are added to this message). *SECTION_SHELL cards are deleted after creation of *PART_COMPOSITE. Then, the section is changed on this card.
- Hourglassing formulation type & parameter
- Number of plies increased
- TFAIL, DFAILM, DFAILS, EFS parameters
- Model clean-up
- Decreasing timestep & remove mass scaling
- Solver: 2022 R1
Unit system: [t,mm,N,s]
SHELL ELEMENT QUALITY CHECK SUMMARY:--------------------------------------------------------------------------------Quality Name Min. val Max. val Allowable #Violated(%)--------------------------------------------------------------------------------Min side length 4.12 5.44 3 0(0%)Max side length 4.77 8.5 30 0(0%)Aspect Ratio 1 1.85 10 0(0%)Warpage 0 0.128 10 0(0%)Min Quad Angle 88.3 90 45 0(0%)Max Quad Angle 90 91.7 135 0(0%)Min Tria Angle 0 0 30 0(0%)Max Tria Angle 0 0 120 0(0%)Taper 0 0.0143 0.7 0(0%)Skew 0 1.27 45 0(0%)Jacobian 0.911 1 0.6 0(0%)Char. length 4.12 5.46 1 0(0%)Area 20.6 45.6 5 0(0%)Feature angle 0 85 30 8192(4.55%)TimeStep 3.98e-07 5.26e-07 1e-07 0(0%)--------------------------------------------------------------------------------#QUADS(%):180224(100%), #TRIAS(%):0(0%), #TOTAL OF FAILED(%):8192(4.55%)--------------------------------------------------------------------------------Fail message from .d3hsp file:
*** Warning 40098 (SOL+98)
ALE time step size is less than dt2ms at cycle 20
Mass scaling time step size of
element id: 456411 has a dt: 5.8372E-07
element id: 350107 has a dt: 5.8372E-07
element id: 354939 has a dt: 5.8372E-07
element id: 359771 has a dt: 5.8372E-07
element id: 369435 has a dt: 5.8372E-07
element id: 374267 has a dt: 5.8372E-07
element id: 379099 has a dt: 5.8372E-07
element id: 388763 has a dt: 5.8372E-07
element id: 393595 has a dt: 5.8372E-07
element id: 398427 has a dt: 5.8372E-07
*** Warning 40101 (SOL+101)
ALE time step size is less than dt2ms.
Further output has been suppressed beyond cycle 21
f a i l e d e l e m e n t r e p o r t time= 1.1307E-05
number of failed solid elements = 0
number of failed beam elements = 0
number of failed shell elements = 1
number of failed tshell elements = 0
shell element 782030 failed at time 1.1307E-05Regards,
July 14, 2023 at 5:54 pm
July 17, 2023 at 8:43 am
- The topic ‘Negative Jacobian – Fail’ is closed to new replies.
5794
