March 14, 2024 at 10:15 pm
c2087845
SubscriberI am trying to run simulations for lift and drag at different angles of attack for an aerofoil. When inputting the lift force coefficients I enter a negative number, this causes an error saying "floating point exception". However I have checked and these values are supposed to be negative. I am using the student edition so im not sure if this is a limitation of that but any help is much appreciated
March 15, 2024 at 11:39 am
Forum ModeratorWhere are you entering a negative number?Â
March 15, 2024 at 2:01 pm
c2087845
SubscriberWhen i enter the x component of lift, the value is negative at the angle of attack I am using
March 15, 2024 at 2:29 pm
c2087845
Subscriberfor some reason it works for my initial setup and solution on fluent but not for the duplicates I am creating for different angles of attack
March 15, 2024 at 2:33 pm
Forum ModeratorHow are you adding the lift component, or do you mean the vector definition? Pictures will help.Â
March 15, 2024 at 2:41 pm
March 15, 2024 at 2:52 pm
Forum ModeratorThat shouldn't have any effect on the solver stability, it's just to report the force components.Â
If the model is failing, check the mesh and boundary settings are suitable: the NACA airfoil has been used as a tutorial/help video in Fluent and also in the Learning content on here.Â
March 15, 2024 at 3:04 pm
c2087845
Subscriberis there a way to quikcly fix the sharp trailing edge in my aerofoil geometry as I believe this may be an isse
March 15, 2024 at 3:29 pm
Forum ModeratorThere are a couple of approaches. Trim the end to give a "blunt" trailing edge or break the geometry to extend the mesh from the trailing edge through the domain.
- The topic ‘Negative components of lift and drag’ is closed to new replies.
5679
1890
1419
