February 23, 2023 at 11:00 pm
larito
SubscriberHello,
I am running my first FSI case in Ansys with the help of the Ansys docs: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_fsi_sec_setup.html
I did everything as said, I run the solution the first time as indicated with no issue but the moment I set the coupling option and try to run the simulation I gt the following error "Update-Dynamic-Mesh failed. Negative cell volume detected" My mesh quality seems fine as seen on the left part of the image bellow.
As part of a possible solution I changed the mesh acouple of time and decreased the time step(0.0001) but non of these tricks worked.
I have no idea what is causing this issue, any help on this or advice is much appreciated.
Thank you
February 24, 2023 at 9:33 am
Essence
Ansys EmployeeHello,
You need to change the settings and additional dynamic mesh zones (eg: maybe boundary zones) need to be defined. You might find more information here: 11.6. Using Dynamic Meshes (ansys.com) Â 44.6. FSI Setup Recommendations for Fluent-Mechanical Couplings (ansys.com)
- The topic ‘Negative cell volume detected’ is closed to new replies.
4602
1510
1386
1209
