June 18, 2019 at 7:48 am
MrFCA
Subscriber -
June 18, 2019 at 8:31 am
DrAmine
Ansys Employee1/Bad convergence behavior
2/Negative Absolute Pressure might tell that water is cavitating inside the Pump.
June 19, 2019 at 7:50 am
MrFCA
SubscriberHello! The first problem was solved (it was due to the boudary conditions). However, the second problem not. Why is it cavitating in this stranger zone? I have followed the step of two videos upload in YouTube (ANSYS How To Videos). This are the links followed:
https://www.youtube.com/watch?v=nBs4Zs3rCRQ
https://www.youtube.com/watch?v=1Mhwtv4DlHY&t=4s
June 19, 2019 at 7:55 am
MrFCA
SubscriberDo not you have manuals on centrifugal pumps to follow the steps and solve the problem correctly?
June 19, 2019 at 8:08 am
DrAmine
Ansys EmployeeNo I do not have the manuals for that. The videos are sufficient.
Which 2nd Problem are you now meaning? The negative Aboslute pressure?
June 19, 2019 at 8:12 am
MrFCA
SubscriberYes, I refer to the negative absolute pressure. How can I solve that?Â
June 19, 2019 at 8:14 am
MrFCA
SubscriberI have been traying a lot of things, but in this zone of the blade I always have this problem. I hace tried with different geometries and it always happens.Â
June 19, 2019 at 8:16 am
DrAmine
Ansys EmployeeIf all settings are correct and convergence is now excellent, then as I said it probably seems cavitating.
June 19, 2019 at 8:19 am
MrFCA
SubscriberBut in real life, negative absolute pressures are not possible. Why the program give me this result?
June 19, 2019 at 8:31 am
DrAmine
Ansys EmployeeThat is why one requires modeling cavitation to avoid negative absolute pressure. Absolute Pressure is only limited for material properties.
June 19, 2019 at 8:32 am
DrAmine
Ansys EmployeeMake some more tutorials especially one related to cavitation.
- The topic ‘Negative Absolute Pressure Centrifugal Pump’ is closed to new replies.
5939
1307
