March 31, 2023 at 9:20 pm
Pratishtha Agnihotri
SubscriberHow can I see a change in the effective index vs voltage in CHARGE for LiNbO3? I browsed through the ferroelectric modulator example provided in Lumerical, it is for BiTiO3. I need to add all electrical and optical properties of LiNbO3 which I can't find on the internet. How should I proceed further?
April 5, 2023 at 6:08 pm
Amrita Pati
Ansys EmployeeHi Pratishtha,
Unfortuanely, you would need those electrical and optical properties to be able to simulate the index vs. bias behavior of LiNbO3 in CHARGE. I would suggest you to look at some existing papers to see if you can get the values. I don't believe there is an alternative approach if we don't have those values.
Amrita -
April 6, 2023 at 4:51 pm
- The topic ‘Neff Vs voltage for LiNbO3’ is closed to new replies.
