Need some help interpreting these Velocity and Pressure contour
    • erwin
      Hi, I'd like some help in interpreting these pressure and velocity contours. For context, this is a wind turbine simulation.
      We used two domains, a stationary (large) and a rotating domain (the wind turbine) to simulate the turbine's rotation.
      I'd like to know if the results make sense as I am not sure how to properly interpret this.
      I genuinely appreciate the help.
    • SRP
      I suggest to please refer the Ansys Innovation Course: Vertical Axis Wind Turbine — Part 1 - ANSYS Innovation Courses
      This help you to understand concept.
      Thank you
      • erwin
        Hi, thank you for providing the link! I will look into this.
  • The topic ‘Need some help interpreting these Velocity and Pressure contour’ is closed to new replies.
