March 4, 2025 at 2:11 pm
gov7295
SubscriberWhile parameterizing a model, I need to switch between predefined sets of dimensions (thickness, length, breadth).
In a simple DOE, I can manually input values, but with Advanced Latin Hypercube Sampling, automating this switch of fixed set of dimesions is challenging. Could anyone advise on an efficient approach? -
March 13, 2025 at 6:51 am
Charudatta Bandgar
SubscriberAre you using this parameterization for geometry modification through scripting?
March 26, 2025 at 12:24 pm
gov7295
SubscriberNo, I am not into scripting as the geometry involves some complex features. I am just parameterizing the ruler dimensions.
March 18, 2025 at 6:41 am
laurennjames1098
SubscriberÂ
You can create a categorical variable representing the predefined dimension sets and use conditional sampling within your Advanced Latin Hypercube Sampling (LHS) setup to ensure the correct fixed set is selected for each sample.
March 26, 2025 at 12:26 pm
gov7295
Subscribercould be please explain in detail regarding the above procedure on how to create a categorical variable and how to use conditional sampling
5824
