3D Design
3D Design
Need insights in Spaceclaim Dimensions Parameterizing
    • gov7295
      While parameterizing a model, I need to switch between predefined sets of dimensions (thickness, length, breadth).
      In a simple DOE, I can manually input values, but with Advanced Latin Hypercube Sampling, automating this switch of fixed set of dimesions is challenging. Could anyone advise on an efficient approach?
    • Charudatta Bandgar
      Are you using this parameterization for geometry modification through scripting?
      • gov7295
        No, I am not into scripting as the geometry involves some complex features. I am just parameterizing the ruler dimensions.
    • laurennjames1098
      You can create a categorical variable representing the predefined dimension sets and use conditional sampling within your Advanced Latin Hypercube Sampling (LHS) setup to ensure the correct fixed set is selected for each sample.
      duck life
      • gov7295
        could be please explain in detail regarding the above procedure on how to create a categorical variable and how to use conditional sampling
