March 12, 2024 at 9:31 am
Vincent Doan
Subscriber -
March 13, 2024 at 9:11 am
Ashish Khemka
Forum ModeratorHi,
What are the material properties? Ate you applying displacement boundary conditions? What if you turn off the small sliding.
Ashish Khemka
March 13, 2024 at 9:22 am
Vincent Doan
SubscriberHi,
I was advised to use 2D plane strain in Static Structural. But this issue happened to me:
when it reach the final destination, the sheet metal disappeared. And I also get this message: "Solver pivot warnings or errors have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully."
How can I resolve this issue? Thank you
March 13, 2024 at 11:35 am
Ashish Khemka
Forum ModeratorHi,
It looks that the model is experiencing rigid body motion. Please search YouTube for a video titled 'Static Structural Analysis on V Shape Plate Bending Process in Ansys Workbench'.
Ashish Khemka
- The topic ‘Need help with sheet metal behavior’ is closed to new replies.
5889
1306
