3D Design
3D Design
Need help to draw this 2D geometry in 3D.
    • rumth
      2D Geometry
      Raju
    • Keyur Kanade
      You can do it using SpaceClaim.
      http://www.spaceclaim.com/en/Support/Tutorials/Essentials/SpaceClaim_Basics_Tutorials.aspx
      If you have case file, please export is as .msh file. Then you can open this .msh file in SpaceClaim. You can refer this .msh file in SpaceClaim to create a new sketch.
      Keyur
    • Keyur Kanade
      You can do it in SpaceClaim
      You can create a sketch in SpaceClaim then use Pull command to convert it to 3D.
      Keyur
    • rumth
      Hi Keyur,
      Thank you for your reply. SpaceClaim seems tough to me. It would be good if I can do it using DesignModeler.
      Raju.
    • Keyur Kanade
      You can use DesignModeler. You will need to create a sketch and use dimensions for the same. Please refer to following video for basics.
      https://www.youtube.com/watch?v=ik7Ns-4zbRI
      It is just 2D sketch. Once you have a sketch, then you can use Extrude or Revolve commands to convert that sketch to 3D.
      Keyur
    • Keyur Kanade
      Here is one more link.
      https://www.youtube.com/watch?v=tOccFv6Al8I
      Hope it helps.
      Keyur
Viewing 5 reply threads
  • The topic ‘Need help to draw this 2D geometry in 3D.’ is closed to new replies.
