December 20, 2023 at 4:22 am
mmia1
SubscriberHi
I want to connect pipe to a tank. I was able to create a hole in the tank shell like below using part trim.
Now I need to create another circle around that hole to model a reinforcing plate like below:
The problem is that there remains some gaps and the circle does not actually lies on the curved surface.
Does anyone know how I can do that? Thanks again.
January 3, 2024 at 4:42 pm
January 3, 2024 at 5:34 pm
Alex R.
Ansys EmployeeHello,
Since the shell tank surface is curved, I would recommend creating a cylinder insted of a circle and cutting the surface of the shell tank with it. Please see below example with two cylinders. I have used Intersection tool in Geometry Tool (GeoTol -> Inter) and ended up with circle on the curve surface.
Let me know if that helps.
Alex.
January 4, 2024 at 1:54 pm
mmia1
SubscriberThanks for the suggestion. Actually thats not I intended to do. I have two keyword files (one for tank and one for pipe) created by Matlab that I imported in lsdyna. Then I created a spline curve at the intersection of tank and pipe using shell intersection like below:
Then I did part trimming option in tank part and removed the elements to represent hole like below:
Now I need to create another concentric circle which would be twice diameter of the hole created above like below:
January 11, 2024 at 6:20 am
January 11, 2024 at 2:54 pm
Alex R.
The workflow for a FEM simulation usually encapsulates first working on the geometries entities -> meshing -> running simulation. Please consider using geometries and geometry tool in LSPP. It's easier to create a cylinder as a geometry and use tools like intersect/trim/stitch to end up with final geometry and then mesh it. Please consider below:
You can find short intro into LSPP here https://ftp.lstc.com/anonymous/outgoing/lsprepost/Training/Intro/LS-PrePost_Intro.pdf
Alex.
January 11, 2024 at 4:48 pm
mmia1
SubscriberHi
Thank you for the reply. The thing is that I have to do a parametric study so I wrote a matlab code that prepares k files. I have a complex geometry of storage fuel tank and pipes together so I thought matlab code to prepare k files would be good for me.
So, is there no option or way available in LSDyna to do the exact operation you showed herein on the mesh part I mean the k file I imported in LSDyna (Fig. below)? If no then I think I have to do this in LSDyna instead of importing k files which will be time consuming.
Thanks again.
- The topic ‘Need help to create a circle on a curved surface’ is closed to new replies.
3792
1388
1188
1090
1015
