TAGGED: Hologram, metasurface, phase-metalens, transmittance
January 2, 2024 at 7:20 pm
Nayem Hosen
SubscriberI want to design an optical metasurfaces. Could someone assist me in obtaining these figure(1) (transmittance intensity and phase shift) varying radius through Lumerical FDTD? I'm having difficulty composing a precise script. The second picture is my structure. The first one I need to calculate and plot.
January 3, 2024 at 7:33 pm
Taylor Robertson
Ansys EmployeeHello Nayem,
I would refer you to the second step of the following example.
Small-Scale Metalens – Field Propagation
With FDTD you can simply sweep of the disk radius, using the required bandwidth to build up the images. Transmission comes directly from the monitors, but it is bit harder to unwrap the phase. See - Metamaterial S parameter extraction.
RCWA is an efficient way of getting these results, but requires sweeping frequency as well.
Best,
January 5, 2024 at 12:38 am
Nayem Hosen
Subscriber -
January 5, 2024 at 9:19 pm
January 6, 2024 at 5:01 am
Nayem Hosen
SubscriberThank you for your kind reply. I got the transmittance intensity graph directly from the sweep result and excitation setting as you suggest.Â
But how can I get the transmittance phase graph? I tried the default script file but shown error. Is there any way to get the phase graph directly as like transmittace intensity?Â
- The topic ‘Need help regarding metasurfaces/metalens (transmittance intensity)’ is closed to new replies.
6284
