TAGGED: aerodynamics, ansys-cfx, cfd-icfluent, cfd-post, multibody-dynamics, rotating-airfoil, udf
October 3, 2023 at 12:55 am
Jean Seixas
SubscriberI have an aerodesign airplane, and i don't know how can i do an aerodynamic analysis with a propeller rotating, to have the data of lift and drag with the turbulence air in the wing root. I saw about UDF (user defined function) and doing it in the Fluent, but i don't know how to do it.
Someone has already done something like that to help?
October 3, 2023 at 12:41 pm
Forum ModeratorYou can use sliding mesh or moving reference frame for the propeller. You then set the rotation speed and airflow speed over the aircraft.
October 3, 2023 at 12:42 pm
Federico
Ansys EmployeeDepending on what your simulation domain looks like, I would suggest using a Moving Reference Frame (MRF) in Fluent to model the propeller motion.
10.2. Flow in Single Moving Reference Frames (SRF) (ansys.com)
You have an example here on what are the meshing requirements for MRF Mixing Tank Tutorial Using Ansys Fluent Meshing Watertight Geometry Workflow - YouTube. Although this is for a mixing tank, the concepts are the same for MRFs.
October 3, 2023 at 1:00 pm
Jean Seixas
SubscriberThanks, I will try this and see what I can get
- The topic ‘Need a rotating propeller in a aerodynamics analysis, how can i do it?’ is closed to new replies.
5824
