October 5, 2023 at 3:57 pm
October 9, 2023 at 4:27 pm
danielshaw
Ansys EmployeeThe Workbench integrated Ansys nCode DesignLife systems are designed to always read the material information from Engineering Data when a solve request is issued from within DesignLife, so any material changes made within the DL UI will be overwritten. You need to "break" the link to WB to enable DsignLife to use material data defined within the DL UI. This behavior is explained in the Intro to Ansys nCode DesignLife training course. -
October 9, 2023 at 8:15 pm
louiee1907
SubscriberThank you, sir. I have broken the 'material map from WB' and the analysis is solved
- The topic ‘nCode Surface Change (Polished,Ground..)’ is closed to new replies.
