July 9, 2024 at 5:27 am
Jeonee
SubscriberHi,
I did fatigue analysis in nCode DesignLife. I create 'Named Selection', and I can see the parts. When I want to see fatigue analysis result on these parts, half of the parts does not have any result. I think, this is bug.Â
July 11, 2024 at 1:37 pm
danielshaw
Ansys EmployeeAre results missing or are they out-of-range? For example, if the calculated stress range is greater than the UTS, DesignLife will not calculate fatigue damage, becasue is assumed that the component will fail with 1 cycle of loading.
July 14, 2024 at 9:36 am
July 14, 2024 at 3:47 pm
danielshaw
Ansys EmployeeAre the results for that area available in the DataValueDisplay table? If so, then it is a graphics issue. If not, then the solver did not calculate the results in that region. Can you file a support case and provide the model? If so, we can dig into deeper.
July 16, 2024 at 5:22 am
Jeonee
SubscriberThe solver did not calculate the results. This image is an example. I did an analysis at university, so I'm so sorry, I cannot share the project.Â
July 17, 2024 at 11:27 am
Jeonee
SubscriberHi sir,
Is there any method to solve this problem? I could not find any information on the internet.
July 17, 2024 at 1:29 pm
danielshaw
Ansys EmployeeSorry, but I cannot debug this behavior without more information. It might be a bug, but I doubt it. What release are you using? Did you try running the fatigue analysis using the Mechanical Add-On?
July 17, 2024 at 9:43 pm
danielshaw
Ansys Employee-
July 22, 2024 at 6:39 am
Jeonee
SubscriberThank you so muchÂ
- The topic ‘nCode Result’ is closed to new replies.
5824
