TAGGED: ansys, beams, modal-analysis, natural-frequency, staticstrutural
March 14, 2022 at 9:26 am
Zabeeullah
SubscriberHow do we calculate the natural frequency at different modes for a fixed-fixed beam with the given data.
Lenght = 2 m
Cross section = 70*30*4 mm
Moment of Inertia Ixx =420565 mm^4
Distance between neutral surface to top-most surface (y) = 35mm
Modulus of Elasticity= 210 GPa
Density= 7405 kg/m^3
Mass per meter= 5.45 kg/m
Apart from this, A point load of 1000N acts on the beam at the centre. Does this load affects the natural frequencies and the modes of the system? Do i need to consider this load while calulating the natural frequency and mode shapes of the beam?
Your help would be appreciated.
Thanks,
Zabee
March 14, 2022 at 2:19 pmChandra Sekaran
Ansys EmployeePlease take a look at ANSYS Innovation courses that introduce modal analysis at /courses/index.php/courses/topics-in-modal-analysis-using-ansys-mechanical/ for how to run a modal analysis.
A load like you describe generally does not have significant effect on the natural frequencies/mode shapes. However lesson 2 in the above course talks about pre-stressed modal analysis where loads could make a significant impact on the natural frequencies (like a tensioned guitar string or a turbine blade rotating at high speed).
Viewing 1 reply thread- The topic ‘Natural Frequency of a fixed-fixed Beam’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3912
1414
1256
1118
1015
