April 19, 2021 at 9:40 pm
Abubakar
SubscriberHi Sir,nI am simulating a free convection problem. So, I don't know which solver(pressure-based or density-based) should I take here?nMy senior suggest me to go with a density-based solver because in natural convection density varies.nI hope you understood my question. TIAnnThank you,nAbubakar khan n -
April 20, 2021 at 11:01 am
Forum ModeratorI'd use the pressure based solver as the fluid is unlikely to be moving in excess of Mach 3. However, I would use a variable density material and make sure gravity was defined. n -
April 21, 2021 at 12:00 am
Abubakar
SubscriberThank you sir for your response. I have a follow-up question. What do you mean by variable density material? TIAnnThank you, nAbubakar Khann -
April 21, 2021 at 11:08 am
Forum ModeratorOpen the materials panel and look at the options for Density. They're explained in detail in the documentation. n -
April 21, 2021 at 11:26 pm
Abubakar
SubscriberOk sir will do that thanks for response. n
Viewing 4 reply threads
- The topic ‘Natural convection’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1256
1118
1015
