March 21, 2020 at 6:18 pm
ecrod
SubscriberHello All.
I've imported my mesh in *.bdf format into Fluent 19.2. However, it is showing rendering issues.
I have no idea what it means. Could someone help me to figure out how to solve it ?
Thanks in advance.
March 21, 2020 at 7:28 pm
peteroznewman
SubscriberI expect this is just the way ANSYS tries to group element faces into "surfaces".
I expect if you just plot the elements, you get a sensible looking mesh.
If you put the .bdf file into a .zip file, you can upload it to your post.
March 22, 2020 at 2:24 pm
March 22, 2020 at 3:25 pm
peteroznewman
SubscriberI opened each of these BDF files in Femap, which is very good at reading NASTRAN files. Attached are the error reports on those files. The element shapes are very poor.
I recommend you create some new geometry in either DesignModeler or SpaceClaim and mesh that in ANSYS.
March 22, 2020 at 3:46 pm
ecrod
SubscriberCan I code in DesignModeler or SpaceClaim ? Or is it only a Graphical User Interface ?
March 22, 2020 at 4:23 pm
March 22, 2020 at 4:25 pm
ecrod
SubscriberI realized, for instance in annulus example, that the mesh looks like fine and the issue is only visible for interfaces view (walls) ?
March 22, 2020 at 4:55 pm
peteroznewman
SubscriberThe quality of the element shape is poor on some elements. For example, the element faces on the inside cylindrical face have a high level of skew. The entire mesh would be improved if it was Hex elements instead of Tet elements.
March 23, 2020 at 1:18 pm
ecrod
SubscriberPeter,
Why when I "Check Case" from Fluent Run Calculation tab, It does not show skewness message issue as "Skewness exceeded 0.98 at "number" cells" ?
I receive a message :Â No recommendations to make at this time.
March 23, 2020 at 6:50 pm
peteroznewman
SubscriberOkay, it is not so bad that Fluent refuses to solve, but the entire mesh would be improved if it was Hex elements instead of Tet elements.
March 25, 2020 at 1:51 pm
March 30, 2020 at 7:15 pm
ecrod
SubscriberHello Peter,
Do you have any idea why it is happening only in Parallel mode ? This is only a visualization issue or could have effect in computation as well ?
Thanks.
March 30, 2020 at 7:49 pm
peteroznewman
SubscriberI have no idea, but if I was going to make up a reason, I would say that those scraggly lines show how the computational domain was broken up for the multiple processors.
- The topic ‘Nastran bulkdata file issue’ is closed to new replies.
6425
