My walls automatically change to interface
    • Nicolo
      I am trying simulate a two-phase flow (co2 and water) transient case. My geometry (refer to pic 1 and 2) consists of two main channels which are connected to each other via 4 very small channels in the middle (pic 2).
    • DrAmine
      Can you list the connections / Interfaces you have in Fluent? That yellow should be part of the interface connection in the top part. If there is an interface the non overlapping part will be treated as wall: there you should define your contact Angle.nnPS: please next time do not write in Bold.n
  • The topic ‘My walls automatically change to interface’ is closed to new replies.
