3D Design
3D Design
My question is as follows
    • liu377997
    • liu377997
      Hello, I would like to ask how the connection between the "Solution" in the Transient Structural module and the "Results" in Fluid Flow (Fluent) is achieved in your video. I followed the same setup in Ansys Workbench, but I am unable to establish this connection at this step. I'm unsure if it is a software issue or something else. I would appreciate your guidance. Thank you, my friend.However, after failing to create the connection between the 'Solution' in the Transient Structural module and the 'Results' in Fluid Flow (Fluent), ANSYS Workbench prompts the message: 'Unable to load ACT extension. If continuation involves self-interaction, you might encounter restrictive behavior.'
    • Rahul
      Prior to version 2021 R1 CFD Post can be used to view the FSI results (Both CFD and Mechanical). CFD Post does not support reading Mechanical 2021 R1 or later results files. Mechanical results could not be loaded in CFD-Post and while making connection from Mechanical solution cell to results (CFD-Post) it will throw an error.
      Ensight supports viewing Combined System Coupling (FSI) results. Load the results of the coupling participants to Ensight ( Fluent/ CFX, Mecanical and SyC Results).
      Please refer a postprocessing tutorial to know more about postprocessing in Ensight Postprocessing System Coupling's Co-Simulation Results (ansys.com).
