April 28, 2021 at 2:31 pm
maryam.rahmani
SubscriberHi,
I have installed Ansys HFSS 2021 recently but my HFSS snap tools (snap to vertex, center,...) are super small such that I cannot see them even using the windows magnifier!!
Also I have the same issue with the Report font size that they are so tiny that reading them is impossible (font size=3).
I have changed them through tools> options>general>.... but it is not set as default and I have same problem every time I open a new project!
Also, the coordinate setting at lower right corner of the page are squeezed together.
Overall, there are lots of serious problems with the display settings with this version of HFSS. I'm using Ansys Electronic Desktop 2019 on my other device from another university ( a separate license) without any problem! Is this a bug with 2021 version?
I have googled and saw there are some display setting issue with HFSS with large displays! But I'm using it on my laptop. Even with large monitor, it should work!!
This problem is so annoying and stops me from working efficiently.
Please help me with this. I appreciate your help.
Best,
Mary
April 28, 2021 at 10:40 pmmaryam.rahmani
SubscriberHi All,
This issue was addressed by one of Ansys technical supports. I appreciate his help so much this is how this problem solved:
1- Right click on the HFSS icon and select properties:
Then select compatibility tab> Change high DPI settings> Check Overwrite high PI scaling behavior and then choose System(Enhanced)
And TADAAAAA.... FIXED!!!!
April 29, 2021 at 12:58 pmPraneeth
Thank you for posting the solution for the issue.
All the very best for your future simulations.
Viewing 2 reply threads- The topic ‘My HFSS snap (snap to vertex, center,…) are super small’ is closed to new replies.
2918
970
852
599
591
