January 30, 2021 at 11:37 pm
YektA
SubscriberFebruary 1, 2021 at 3:39 pmAniket Chavan
Forum ModeratorDoes this happen with every geometry or a specific one? If happens with every geometry try resetting the AppData for the version that you are using. If this is happening for a specific model try importing the model in SpaceClaim and see if you can see it there.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnFebruary 1, 2021 at 10:08 pmYektA
SubscribernThanks for your answer, first of all this happens in every geometry and geometries do not open in spaceclaim.nnFebruary 2, 2021 at 1:21 pmAniket Chavan
Forum ModeratorSo does appdata reset help?nFor resetting the appdata:nclose all workbench sessionsnopen %appdata%/Ansys (assuming that you are using windows)nrename v202 to v202_old (assuming that you are using 2020R2)nand recheckn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnOctober 5, 2023 at 3:20 pmAlvin Suhardi
Subscriber-
October 6, 2023 at 10:40 am
Antonio Manduca
SubscriberHello i have the same problem, and it isn't showing in the meshing ambient too, however it is visible in spaceclaim and setup, have you found a solution?
November 9, 2023 at 5:31 pmRiley Fosnot
SubscriberI have the same problem, does anyone have a solution yet?Â
Viewing 5 reply threads- The topic ‘My geometry is not visible in the graphics window in designmodeler’ is closed to new replies.
5754
