December 19, 2023 at 12:13 am
christopher.t.nemecek
SubscriberHello,
Is it possible to use multizone meshing for a region within your domain while also being able to use poly or poly-hexcore for the rest of the domain? For example, if you have a cylinder not aligned with the cartesian coordinate system, can you multizone mesh that to align the cells to the flow direction while the connecting domain is poly or poly-hexcore?
December 20, 2023 at 7:14 pm
Federico
Ansys EmployeeHello,Â
yes, that is possible. You just need to create separate cell zones for this. When using MultiZone, you do not need to mesh the entire domain. You will find a task for generating the volume mesh in the remaining zones of your domain after the MultiZone meshing is complete.
December 20, 2023 at 7:56 pm
SubscriberOk. From my understanding though, if you wanted to mesh the non-multizone region and have a conformal mesh/interface, Ansys only supports Tet or Hexcore. If you wanted to use Polyor Poly-Hexcore in the rest of the domain, you'd need a non-conformal interface. Correct? If so, it seems like the ability to have a conformal multizone/poly mesh would be nice. Star-CCM+ has this capability.
December 20, 2023 at 8:34 pm
Federico
Ansys EmployeeYes, you are correct. If you have a hex-type multizone mesh, you currently cannot have a conformal interface with a Polyhedral/polyhexcore zone.
- The topic ‘Multizone Meshing with Polyhedral or Poly-Hexcore’ is closed to new replies.
3150
1013
945
858
797
