Preprocessing
Preprocessing
Multizone Meshing Stuck at 70%
    • yappyap
    • Keyur Kanade
      If you are using student license then it has limitations on no. of nodes. Please cross check. nIf you not using student license then you can go ahead with more no. of nodes. nFrom the image it looks like surface body with many small faces. You have also used virtual topology. Can you please check if you can simplify geometry in SpaceClaim before coming to meshing. Please check if you can use different meshing method to mesh. Make sure that you have applied correct mesh sizing.Regards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • yappyap
      n
    • yappyap
      nI tried to use the Automatic Method instead but tri elements keep showing. How can i obtain a more even mesh?nn
    • yappyap
      I am not using student license! I dont think there's other ways i can simplify the model in SC.n
    • Keyur Kanade
      Can you reduce the model size? Is it symmetric?nCan you modify it in SC so that less no. of edges come in meshing? nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • yappyap
      no i can't reduce the model size. no it is not symmetric. and i dont think there can be other modifications made in SC anymore.nn
    • Keyur Kanade
      For testing purpose, split the geometry in SpaceClaim. Take only small portion of geometry and try to mesh it. Change settings as required. Once you successfully mesh that small portion, you can use same settings for entire model. Please check if you can use different method as patch confirming tetra etc. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
Viewing 7 reply threads
  • The topic ‘Multizone Meshing Stuck at 70%’ is closed to new replies.
