Multiple mode geometric Imperfection
    • venugopal4048
      Hello all!
      I am doing nonlinear buckling analysis, I need to incorporate the geometric imperfection into the model. I already know how to add geometric imperfection by using one mode shape. I would like to add a combination of mode shapes as a geometric imperfection(like modes 1,2,3 in linear buckling analysis). Is it possible to add it in workbench?
      Thanks in Advance!
    • jj77
      See this video: In the upgeom.inp they show in the video you need to add another line with UPGEOM for a second mode (so say we want first and third mode to be combined). So the upgeom file would be then:
      /prep7
      UPGEOM, 0.001, 1, 1, file, rst,
      UPGEOM, 0.001, 1, 3, file, rst,
      cdwrite,db,file,cdb
      Or one could loop over ten modes adding a tenth of each mode (this is from an old help manual v16 ch 21.6):
      /prep7
      *do,i,1,10
      upgeom,0.1,1,i,file,rst ! Add imperfections as a tenth of each mode shape
      *enddo
      cdwrite,db,file,cdb
      https://www.youtube.com/watch?v=AGkE-Be3tEs
    • nikhil.gupta
      The vedio link shared above is based on Ansys version 12 in which the 'finite element modeler' option was available. Refer  fig 1 below.
      In current versions of Ansys like 2023 R2, we don't have the option to add 'Finite element modeler' in project schemetic. Refer fig 2 below.
      As 'finite element modeler' option is not available now, than how can we proceed to include imperfections in geometrical model for two mode shapes ( say mode 1 and mode 3) in latest versions of Ansys?
      Fig 1: Ansys Version 12, Finite element modeler option available
      Fig 2: Ansys Version 2023, Finite element modeler option not available
      Thanks and Regards.
    • erik.kostson
      Hi
      Yes it is (it is not visble by default) – to show and use it  in the wb project page go to the bottom left part and press “View All/Customize”, then it can be found under the component systems.
      If you have any other question open up a new post – this is an old one and is closed now.
      Erik
  • The topic ‘Multiple mode geometric Imperfection’ is closed to new replies.
