August 11, 2017 at 2:33 pm
MehmetK
SubscriberÂ
Hi Â
I am calculating the power output of a wind turbine using ANSYS Fluent. I am using Multiple Frames, one is the moving/rotational frame, and the other one is stationary frame (outer frame), see attached picture please.Â
I barely can find studies in the literature who used multiple frames (one rotational one stationary) together with the periodic boundary condition. I am using multiple frames together with the periodic boundary condition and my results are close to experimental results. I define periodic boundary condition for rotating/moving frame and stationary domain separately in the mesh interface section. For the rotatinal domain, I only define interfaces and wall (blade). Is there something wrong?
Thank you very much
Mehmet
August 30, 2017 at 11:16 am
Holger Grotjans
Ansys EmployeeLooks okay. Why do you think something is wrong?
For rotating machinery you can also have a look at CFX, which has specific turbo pre- and post-processing available.
- The topic ‘Multiple Frames for Wind Turbine Analysis’ is closed to new replies.
1520
1386
1209
