April 6, 2020 at 5:02 am
cfd_learner
Subscriber -
April 6, 2020 at 10:07 am
Forum ModeratorYou need to label both fluids with different names. I'd also label the bounding surface with "interior-rotating" or similar to make those a named entity. I've not tried it for a few versions so let us know how you get on.Â
April 6, 2020 at 10:38 am
cfd_learner
SubscriberI labeled as "fluid-static" and "fluid-moving". The problem is how to tackle interfaces between static/moving zones? Whether I have to use "share topology" option or not. Somehow I end up with meshing of one zone only.
April 6, 2020 at 1:06 pm
Forum ModeratorDid you subtract+retain the rotating volume? You'll need to tell Fluent Meshing there are two fluid regions if it doesn't pick them up at the volume meshing stage.Â
April 6, 2020 at 1:40 pm
cfd_learner
SubscriberHow to tell fluent meshing under "watertight geometry workflow"?
April 6, 2020 at 3:23 pm
cfd_learner
SubscriberSomehow, I managed to do multi-region meshing.Â
Under "Watertight Geometry Workflow", --> Describe Geometry --> Check to YES Apply Share Topology -->Advanced --> Join & Intersect Method -->Join & Intersect..
This way I managed to mesh two fluid zones with interface boundaries.
Now I am stuck with "Periodic Boundaries". Only managed to "Apply Periodic Boundaries" to one pair of a single fluid zone.Â
Any help regarding this?
April 6, 2020 at 3:55 pm
Forum ModeratorI'll have a look at the enclosed volumes tomorrow: sounds like it's changed since I last tried it.Â
There shouldn't be any periodic boundaries, the only "odd" ones should be interface zones?Â
April 6, 2020 at 4:09 pm
cfd_learner
SubscriberYes, there are interfaces, If I want to simulate only one sector (one blade) with periodic boundaries, then there exists.
April 7, 2020 at 6:16 am
cfd_learner
SubscriberNo solution yet for multi-region meshing with interfaces....stuck badly.Â
The following solution already mentioned also not working.
- The topic ‘Multiple-Cell (fluid) Zone Meshing in Ansys Fluent’ is closed to new replies.
3737
1328
1163
1090
1014
