December 31, 2024 at 2:28 am
ngocminh2532003
SubscriberHello,
I am simulating the MEMS model on Ansys using multiphysics simulation. I created a block around the object and gave it air material. I want to analyze its effect only on the object's convection, so I do not add any electric material property. But my simulation has a problem. Can somebody help me to check my simulation?
Or there is any way to analyze the object's convection with the air that does not have to create a block around the object?
Thank you,
Ngoc MinhÂ
December 31, 2024 at 1:03 pm
ErKo
Ansys EmployeeHi
Does not need to model the air - just use a convection boundary condition in the the thermal analysis.
Instead also of connecting the two analysis use the thermal-electric where you do it all in one (so both thermal+joule heating due to an electric part/voltage).
Search for thermal electric there are many tutorials.
Erik
January 1, 2025 at 9:19 am
ngocminh2532003
SubscriberÂ
Thanks for your reply. Is there any difference between connecting two analyses and doing a thermal-electric analysis in one?
Regards,Â
Ngoc MinhÂ
January 2, 2025 at 9:56 am
ErKo
Ansys EmployeeÂ
Yes the first one is a one way coupled analysis, and the later a 2 way coupled (e.g., here resistivity can be a function of temp and be updated throughout the analysis and other direct effects can be accounted for in 2 wat coupl.).
All the best
Erik
5729
