Multiphase shear stress
    • Simon Lejon
      I am trying to simulate a rotating vial partially filled with water. The goal is to calculate the shear stress in the water. Althought I can calculate the shear stress of the 'mixture' (because of multiphase), I am struggeling with calculating the shear stress in the water (not in the air). Can someone give me some advice?
      Thanks in advance!
    • SRP
      You can create an iso-surface to mark the interface between the water and air. This allows you to focus on the water phase and calculate the shear stress accordingly.
      Hope this helps you.
    • Simon Lejon
      Hi
      Thank you for the respons but I still can't select the water-phase when calculating the (wall) shear stress. I can only select 'mixture' when selecting 'max' -> 'wall shear stress'.
      Thanks in advance.
  • The topic ‘Multiphase shear stress’ is closed to new replies.
