February 9, 2024 at 1:46 am
mohamed.elfaham
SubscriberI am trying to find the equations that calculate the Surface Heat transfer coefficient, Wall adjacent Heat transfer coefficient and Wall temperature in ANSYS FLUENT from the manual guide.Â
I am doing 2-D simulation to calculate the multiphase HTC and to Capture the volume fraction of the vapor phase. I am using ethanol liquid and vapor, applying the VOF model, multiphase model, and Boiling (evaporation and condensation) Model. I have a constant heat flux applied and also a constant saturation temperature.
please help me to find how these variables are computed in the software under the conditions applied, also If I need to use a specific HTC equation, how I can insert it and make a contour from it.Â
Thanks -
February 9, 2024 at 11:57 am
Forum ModeratorThe HTC values will be in the Field Function section in the User's Guide - 42.4 in the 2024R1 Fluent User's Guide.Â
Solver equations will be covered in the Theory Guide, and the heat transfer used by Fluent will be included in those sections.Â
February 10, 2024 at 1:07 am
mohamed.elfaham
Subscriberhow can I find the user guide 2024R1? can you provide a link for it.
February 12, 2024 at 10:06 am
Forum ModeratorClick on Help in the Fluent solver.Â
- The topic ‘Multiphase Heat transfer coefficient’ is closed to new replies.
