October 21, 2024 at 5:36 pm
flo.schuster
SubscriberHello,
I am trying to produce a structured grid of a somewhat complicated structure (as it consists of multiple materials)
The Blocking worked as intended but when I try to specify the nodes along the first edge, the number of nodes is transferred to other edges as well. Furthermore, some artificial grid-lines are also produced and I do not know why.Â
Other forum posts suggested to permanently delete the VORFN blocks, which did not help.
I deleted and merged some blocks, might this lead to complications?
What are possible fixes for this problem?
Thanks in advance and best regards
October 22, 2024 at 10:26 am
abhishek.roy
Ansys EmployeeHi, if you are using ICEM CFD please check edge to curve and face to surface association. If you are using any other software let me know.Â
October 22, 2024 at 12:18 pm
flo.schuster
SubscriberExactly, I am working with ICEM. So if I have multiple shorter edges and one long along a single curve, like seen for the long vertical green block, I need to split the curve into smaller sections, correct?
Thanks a lot
October 22, 2024 at 1:49 pm
abhishek.roy
Ansys EmployeeWhen you split the blocks make sure to split through all. Also, check associations.Â
6159
