multi track Laser moving in mechanical (Thermal Transient)
    • Sara.Ranjbareslamloo
      Hello, I am working on capturing residual stress in two dissimilar materials using ANSYS Workbench. Since there is no direct module for dissimilar materials, I am simulating the transient thermal behavior and coupling it with structural analysis.
      I have written a command for laser movement using a 3D Gaussian heat source, but now I want to extend it to handle multiple laser tracks. I attempted to use element birth and death for each track and apply the heat source individually. However, the issue is that all the commands are being applied simultaneously, whereas I need them to be executed sequentially at different times.
      Does anyone have suggestions on how I can achieve this?
      I mean I want to do exactly like this tutorial Additive Manufacturing with Element Birth & Death ANSYS Workbench (3D Goldak heat source)
      here is my command for one laser track
      g=0.3 !absorbity
      p=230 !Laser Power in watts
      w=0.001    !radius of moving source
      A=(2*g*p)/(22/7*w**2)
      B=-3
      C=0
      D=900 !scan speed
      E=0
      F=w**2
      *DIM,HEAT_FLX1,TABLE,8,14,1,,,,0
      ! Begin of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F)
      *SET,HEAT_FLX1(0,0,1), 0.0, -999
      *SET,HEAT_FLX1(2,0,1), 0.0
      *SET,HEAT_FLX1(3,0,1), A
      *SET,HEAT_FLX1(4,0,1), B
      *SET,HEAT_FLX1(5,0,1), C
      *SET,HEAT_FLX1(6,0,1), D
      *SET,HEAT_FLX1(7,0,1), E
      *SET,HEAT_FLX1(8,0,1), F
      *SET,HEAT_FLX1(0,1,1), 1.0, -1, 0, 1, 2, 2, 19
      *SET,HEAT_FLX1(0,2,1), 0.0, -2, 0, 2, 0, 0, -1
      *SET,HEAT_FLX1(0,3,1),   0, -3, 0, 1, -1, 17, -2
      *SET,HEAT_FLX1(0,4,1), 0.0, -1, 0, 1, 20, 3, 1
      *SET,HEAT_FLX1(0,5,1), 0.0, -2, 0, 1, 3, 2, -1
      *SET,HEAT_FLX1(0,6,1), 0.0, -1, 0, 1, -2, 2, 21
      *SET,HEAT_FLX1(0,7,1), 0.0, -2, 0, 2, 0, 0, -1
      *SET,HEAT_FLX1(0,8,1), 0.0, -4, 0, 1, -1, 17, -2
      *SET,HEAT_FLX1(0,9,1), 0.0, -1, 0, 1, -3, 1, -4
      *SET,HEAT_FLX1(0,10,1), 0.0, -2, 0, 1, 18, 3, -1
      *SET,HEAT_FLX1(0,11,1), 0.0, -1, 0, 1, -2, 4, 22
      *SET,HEAT_FLX1(0,12,1), 0.0, -1, 7, 1, -1, 0, 0
      *SET,HEAT_FLX1(0,13,1), 0.0, -2, 0, 1, 17, 3, -1
      *SET,HEAT_FLX1(0,14,1), 0.0, 99, 0, 1, -2, 0, 0
      ! End of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F)
      sf,s1,hflux,%HEAT_FLX1%
    • dlooman
      Birth and death is only needed uf you are adding or subtracting material.  It seems like you would have 3 functions and 3 SF loads, one for each track.  Then in a transient analysis they could be solved for sequentially like below:
      /solu
      antyp,trans
      time,100
      solve
      sfdele,all,all
      sf,s2,hflux,%HEAT_FLX2%      ! 2nd track
      time,200
      solve
      sfdele,all,all
      sf,s3,hflux,%HEAT_FLX3%
      time,300
      solve
      Thank you for your reply, actually in addirive manufacturin (LPBF) which I am going to model it, the process is adding layers but I want to add in horizental (see the below link). In dding layers, it was ok I could define offset time in the equation in Y direction and using EBD model it, but for horizental I am not able to model it, I tried the code you wrote and add em for each track but just first laser track works and second/third track didnnt activated, also I tried to use another seperate command for that ; so I defined laser trackks in three different commans and anded the fourth command for applying the heat fluxes, but result was the same. just fist track moves and gives result.
    • dlooman
      If the issue is related to Additive it would be good to create a new post to possibly get a response from someone knowledgeable on Additive.
