February 20, 2023 at 12:14 pm
nastyashustic
SubscriberQuestion about multi-step analysis.
I have two import pressures, one acting after the other in static, i.e. I apply one pressure, the geometry deforms from it. Next, a second pressure is applied to the deformed model and I look at the deformation at the end.
I do 2 load steps simply.
 Please let me know if I'm doing the right thing.
The pressures come from the CFD calculation. After the first application of pressure, I pass the deformed model to the calculation of aerodynamics, then they give me new pressures and I apply them.
February 23, 2023 at 2:35 pm
Chandra Sekaran
Ansys EmployeeHi, is the questions if it is OK to apply 2 different pressures in 2 different load steps? Can you elaborate on the question?
- The topic ‘Multi-step analysis, External pressure in static analysis’ is closed to new replies.
