June 23, 2023 at 7:39 am
Prashant Jha
SubscriberHello all,Â
I am new to Fluent and have never used multi-phase VOF model. I am solving a problem which is described below: A 2D rectangular container with solid wax at the bottom and oil at the top heated from below by a bulb and cooled from top. The side walls are at room temperature. So, which how to model this situation, I mean how to describe the solid and liquid phases and how to make interaction between them??Any help would be highly appreciated.
Thank You
June 23, 2023 at 10:14 am
Forum ModeratorYou need to do some reading, I'd start with the Learning section on here, and then in documentation, which also includes some tutorials.Â
VOF, solidification & melting, transient and heat transfer are good starting areas to look into.Â
June 23, 2023 at 2:36 pm
Prashant Jha
SubscriberThanks for your reply, it would be great if you could share the learning link
June 23, 2023 at 2:50 pm
Forum Moderator/courses/
- The topic ‘Multi-phase VOF’ is closed to new replies.
4848
1587
1386
1242
