May 12, 2021 at 4:21 pm
Krishna_M_j
SubscriberI am modelling a single cell using MSMD NTGK model. I need to know what the 'Reference capacity' is to complete the input parameters of the cell. It is asked under the MSMD model dialogue box. Thank you in advance.
May 13, 2021 at 1:27 amNavya Chode
Which Ansys tool are you using and can you provide some screenshots of your model and the windows where you have doubt, for better interpretation?
Regards Navya
May 16, 2021 at 5:24 amKrishna_M_j
SubscriberMay 18, 2021 at 2:31 pmwcao
Hello The reference capacity is explained in the theory guide:
The link is here:https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_th/flu_bat_model_ECMs.html
May 18, 2021 at 2:41 pmKrishna_M_j
SubscriberThank youOctober 29, 2021 at 12:54 amayodeji.adeniran
SubscriberThe Qref is the capacity of the battery used for the experiment from which the NGTK parameters were extracted. If you are using the default FLuent Parameter then just leave it as the default which i believe is like 32.77AH.
Viewing 5 reply threads- The topic ‘MSMD battery model’ is closed to new replies.
5664
1890
1419
1304
