November 28, 2024 at 8:39 am
November 28, 2024 at 10:03 am
Forum ModeratorAs small as possible but big enough to avoid artificially constraining the mesh into the gaps.Â
November 29, 2024 at 12:57 pm
luna6362
SubscriberHi Rob! Thank you for your response!
May I ask a question regarding the streamline breakpoints between the static domain and the moving region?
I am trying to enhance the mesh in the moving region, but there are still breakpoints present.
Is it possible to make the streamline and the color of the velocity smoother?
November 29, 2024 at 1:24 pm
Forum ModeratorYou may. If that's CFD Post check the pathlines in Fluent. CFD Post and Fluent's rotating zones don't always play well.Â
November 29, 2024 at 1:30 pm
luna6362
SubscriberThank you!🤣
Yes this is CFD-Post. So it is recommend to see the streamline in Fluent directly?
November 29, 2024 at 1:34 pm
Forum Moderator:)Â
Yes. We did recommend CFD Post for Fluent for a few versions but upgraded Fluent's functionality to negate the need, and only train that, as of about R19.Â
November 29, 2024 at 1:42 pm
luna6362
SubscriberI just looked at the streamlines directly in Fluent, and the effect is great!
If I don't check the Relative Pathlines option, does it show me the streamlines based on absolute velocity?
How should I adjust it if I want to increase the number of streamlines?
Sorry for having so many questions. Thank you so so so much!!
November 29, 2024 at 1:47 pm
Forum Moderator-
November 29, 2024 at 1:57 pm
luna6362
SubscriberThank you so much!
I'm actually still not quite sure what the actual difference is between the streamlines drawn based on absolute velocity and those based on relative velocity.
If the streamlines are drawn based on absolute velocity, they represent the flow field observed from a stationary coordinate system.
If the streamlines are drawn based on relative velocity, they represent the flow field observed from a moving coordinate system.Â
I'm not sure if my understanding is correct, haha. It's really difficult to fully grasp the MRF method.
November 29, 2024 at 2:58 pm
Forum ModeratorMRF is simple once you work out what it's doing, but never gets easy to explain.Â
5719
