June 6, 2019 at 5:11 am
neuvrk
SubscriberHi Everyone,
I am working on Ansys Fluent 19.2 , I am getting this error(shown below) when i use UDF for a multiphase simulation, but there is no problem with UDF. Problem here is sometimes its working fine and sometimes not, when i started same simulation freshly, Iterations got terminated by this error at beginning.
Node 0: Process 10964: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
June 6, 2019 at 11:04 am
Forum ModeratorMaybe a network issue? Are there any other messages just before this happens? When you say there is no problem with the UDF, do you mean it compiles OK or that it's worked before? It's possible to have a UDF where the code is correct (in terms of the language) but the maths causes problems as it's calling values that don't exist.Â
June 6, 2019 at 1:51 pm
Kalyan Goparaju
Ansys EmployeeDo you have any UDMI's in your UDF? If so, you will need to "initialize" them before you can use them.Â
June 7, 2019 at 5:44 am
neuvrk
Subscriber`Thanks for reply, Mr.rwoolhou and Mr.Kalyan Goparaju
but, I don't use use any UDMI in UDF, my code is simple obtaining volume fraction for every timestep using DEFINE_ADJUST macro, here i,j are cell indices are used in vof array.Â
#include "udf.h"
Thread *t;
Thread **pt;
face_t f;
cell_t c;
real h = 0.0004;Â Â // grid size
real vof[25][25];
DEFINE_ADJUST(vol_frac,domain)
Domain *pdomain = DOMAIN_SUB_DOMAIN(domain,P_PHASE);
mp_thread_loop_c (t,domain,pt)
    Thread *tp = pt[P_PHASE];
    begin_c_loop_all(c,t)
   C_CENTROID(X,c,tp);
   i = floor((X[0]-h/2)/h) ;
   j = floor((X[1]-h/2)/h) ;
   vof[j] = C_VOF(c,tp);
   end_c_loop(c,t)
June 7, 2019 at 10:32 am
Forum ModeratorDoes it run without the UDF?  What do you want to do with the volume fraction?Â
June 7, 2019 at 12:19 pm
neuvrk
Subscriberyes rwoolhou, Its running with out UDF and also if i commented out the below line my simulation is running
I need to get cells with volume fraction 0.5 // which i haven't shown hereÂ
- The topic ‘MPI Application rank 0 exited before MPI_Finalize() with status 2’ is closed to new replies.
3832
1394
1188
1100
1015
