October 17, 2020 at 10:38 pm
alisul692
SubscriberHi every one can anybody help me.nwhen i use the UDF to get resolved Reynolds stresses in fluent we get that errorMPI Application rank 0 exited before MPI finalization() with status 2 -
October 19, 2020 at 12:40 pm
Karthik Remella
AdministratorHello,nAre you compiling your UDF? If so, are you able to successfully compile it without any error messages? Could you please post a screenshot?nThank you.nKarthikn -
October 30, 2020 at 7:54 pm
alisul692
SubscriberThank you for answer me Mr. Kermellanplz can you tell me how can i plot RMS velocity without use UDF? because all UDF post that i used have an errorn -
October 30, 2020 at 8:29 pm
Karthik Remella
AdministratorWhich turbulence model are you using for your simulation? Also, could you please post a screenshot of your UDF as well as the error message you are receiving? Are you getting this error message when you are attempting to compile the UDF or when you are running the model?nPlease embed your screenshot directly here so we can have a look.nThank you.nKarthikn -
October 31, 2020 at 3:08 pm
November 2, 2020 at 2:21 pm
Karthik Remella
AdministratorHi,nFrom the error message, it seems like your UDF is not meant to be used on Parallel processors. Are you able to compile it successfully for a serial run? If that works, then you will need to parallelize your UDF before you can compile it on parallel processors.nThank you.nKarthikn -
November 10, 2020 at 8:45 pm
alisul692
SubscriberHi Mr.Kremella i used it for parallel and serial but the error still appearsn -
November 11, 2020 at 2:49 pm
Forum ModeratorCan you use the built in compiler in 2020R2? The error is that the code isn't compiled: ie you've not built the libudf needed for the solver. n -
November 12, 2020 at 2:47 pm
alisul692
SubscriberThanks for reply Mr. Rob, I used version 2019 R3 not 2020 R2nSo I need to upgrade to a new version??n -
November 12, 2020 at 4:19 pm
Forum ModeratorTo use the built in compiler, yes you do. Otherwise you need to get the Microsoft one working. n -
November 12, 2020 at 5:25 pm
alisul692
SubscriberI have a Microsoft visual studio 2017 and 2019 but the problem is still nfluent dont able to solve yplus unless use UDF so I need to solve this problemnn -
November 12, 2020 at 5:56 pm
DrAmine
Ansys EmployeeStart Fluent from Visual Studio command prompt then try to compile.n -
November 14, 2020 at 2:07 pm
JD_JN
SubscriberHello,nI had the same issue and this is how I fixed it. Following these steps, you don't have to launch fluent from command prompt!Install Visual Studio 2017 Community Edition with C++ options (ANSYS 2019 doesn't support newer versions of VS such as MSVS 2019)nGo to Control Panel -> System and Security -> System -> Advanced System Settings -> Environment VariablesnGo to the bottom section named 'System variables' and then double-click to open 'Path'nThere, create 4 new entries (mentioned below as steps 5, 6, 7, by clicking on 'New':n%SystemRoot%\system32n%SystemRoot%nC:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\bin\Hostx64\x64 (This is the location for 'nmake' in MSVS 2017 Community Edition)n\ANSYS Inc\v194\fluent\ntbin\win64 (This is for ANSYS 2019, your version number will change according to the one you have installed)nMake sure that the entries in steps 5 - 8 are at the top most rows of the path variables, i.e., entry 5 should be in row 1, entry 6 should be in row 2, entry 7 should be in row 3, and entry 8 should be in row 4. You can change their row positions using 'Move Up' option in the system variables dialog boxnClick OK and exit out of the Path variables dialog box, as well as exit out of the Environment variables dialog box and System properties dialog boxnRestart systemnStart FLUENT. In the FLUENT Launcher, click on 'Show More Options'nMake sure that the working directory location is the location of your folder containing your UDF and then click OK to launch FLUENTnNow you will be able to build and load your UDFs.nCheers!nn -
November 14, 2020 at 5:00 pm
alisul692
SubscriberThanks DrAmine for reply i used this method and the error appears as the figure aboven -
November 14, 2020 at 5:01 pm
alisul692
Subscriberthanks JD_JN I will try this n -
November 14, 2020 at 6:42 pm
JD_JN
SubscriberSure! Let me know how it went. n -
November 19, 2020 at 11:40 am
alisul692
SubscriberJD_JN its work thanks for youncan I asked you if you have a UDF for u RMs of large eddy simulation can you send it to me?.
Viewing 16 reply threads
- The topic ‘“MPI Application rank 0 exited before MPI finalization() with status 2’ is closed to new replies.
