September 3, 2024 at 5:29 pm
deepesh.p.gurdasani
SubscriberÂ
1) Is MPC to be only used between 2d (Shell/beam) to 3d(solid) contact ?
2) While using MPC, if there is a gap between 2d and 3d bodies, should pinball radius be adjusted accordingly? Or MPC will do the needful and pinball would be kept at program controlled.
3) Pinball radius should just be equal to gap? suppose for 1 mm gap, its ok to give to 1 mm as radius ? (even this will show as Orange coloured in contact tool).
If possible, please share suggestions pointwise.
Thanks in advance
September 4, 2024 at 11:21 am
ashish.khemka
Forum ModeratorHi,
The following two links should help you:
9.6.3.3. Advanced Settings (ansys.com)
Be a Pinball Wizard with Contact Regions in ANSYS Mechanical - PADT (padtinc.com)
Ashish Khemka
