Moving vertices of mesh in Spaceclaim
    • Saad Sultan
      Hello Everyone,
      I had been following a tutorial "Workshop2: Basic Mesh Control" with an example of Disk_Seal geometry in the course "ANSYS Spaceclaim Meshing for FEA. Whenever I use Match Control for meshing, the vertices are mapped incorrectly. I have figured out where the vertices should be located but I'm unable to move the mesh vertices.
      Here it the original geometry of Disk:
      I followed the instructions to generate a mesh like:
      but actually what I get is:
      I'm quite aware where should these red and green vertices be located but they are not mapped correctly. How can I move these vertices onto the target body ?
      best regards,
    • Deepak
      I tried meshing the same model, and it works fine. Please cross-check whether you have given any size controls to the model before meshing.
      Refer: Aligning Block Vertices (ansys.com)
      Thanks,
      Deepak
