March 30, 2024 at 4:21 pm
Adeleine Cabrera
SubscriberHi. I have modeled a reinforced concrete beam to column connection. After analyzing the total deformation on Transient Structural, the stirrups inside the concrete looked like this.
The stirrups are set to LINK type while the concrete is just solid. I already made the whole structure to have a shared topology.
I'm trying to analyze but, this error stopped the analysis:
"The value of UZ at node 4111 is 3.855907948E+09. It is greater than  Â
 the current limit of 1000000 (which can be reset on the NCNV command).Â
 This generally indicates rigid body motion as a result of an         Â
 unconstrained model. Verify that your model is properly constrained."This node is found on the stirrups. So the problem lies on the stirrups. I have already followed video tutorials but, they seem not to work.Â
The stirrups initially looks like this and should move with the concrete and longitudinal:
I tried to analyze again and the stirrups are still not moving:
Kindly help me with this. Thank you.
April 2, 2024 at 7:32 am
ErKo
Ansys Employee-
April 2, 2024 at 10:17 am
Adeleine Cabrera
SubscriberHi. Sorry, I thought the probem is because of the 3d model.
Does using Reinforcement model type allows the use of element LINK180? I need the stirrups and steels to have this element.
Thank you!
- The topic ‘Moving Stirrups’ is closed to new replies.
6029
