July 8, 2020 at 4:57 pm
Rajneesh
SubscriberI am trying to simulate a pin on disc model in which a flat plate has to move in a circular path but without changing its orientation or say it has to revolve around a given point without rotation. In the attached screenshot, I have to implement the motion such that the plate moves in a circular path in the XY Plane without any change in its orientation in the space.
Please help me with this and suggest the possible way to do this.
July 8, 2020 at 5:04 pm
peteroznewman
SubscriberAdd a "dummy body" to the model. Put a revolute joint to ground on the dummy body at the center of rotation. Put a revolute joint at the radius of the circle you wish to be on the path. That revolute joint is between the dummy body and the plate. Add two joint loads: one for each revolute joint. The joint load at the center has a positive rotational velocity about the Z-axis and the joint load at the radius has an equal but negative rotational velocity about the Z-axis.
July 9, 2020 at 6:28 am
Rajneesh
SubscriberThank you sir for your help.
It is now moving as expected but the solver is showing error that "Contact status has experienced an abrupt change. Check results carefully for possible contact separation." Please help to remove this warning.
Rajneesh
July 9, 2020 at 12:33 pm
peteroznewman
SubscriberIf some contact was automatically created when you brought in the "dummy body", delete that contact.
July 10, 2020 at 2:54 am
Rajneesh
SubscriberThanks a lot sir. It worked.
Rajneesh
- The topic ‘Motion in a circular path in Transient Structural’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
