November 2, 2018 at 3:54 am
ShamsHammoud991
SubscriberHello, i want to define a material with Mooney-Rivlin model, i have those parameters C1,C2,D1,D2.
What i have to define also to make sure that model will work?
November 2, 2018 at 11:59 am
Sandeep Medikonda
Ansys EmployeeShamsHammoud991,
 A 2 parameter Mooney-Rivlin Material model would only require C01, C10, and d (good to have this but not absolutely necessary). Please see this section from the help.
 You might also find this discussion useful.
Sandeep -
November 7, 2018 at 7:10 am
ShamsHammoud991
SubscriberSandeepMedikonda
thank you for answer, but i can't see the help section beacuse i don't have a customer portal login
i will try to use 2 parameter, thank you. -
November 7, 2018 at 11:54 am
Sandeep Medikonda
Ansys EmployeeAll help starting in v19 has been moved online and you don't need access to the customer portal to get those. Please see these 2 links on getting access to help.
Sandeep
Guidelines to the Student Community -
November 19, 2018 at 1:41 am
- The topic ‘Mooney-Rivlin Models’ is closed to new replies.
5994
1307
