April 11, 2024 at 4:53 pm
April 12, 2024 at 7:16 am
Aurojyoti Prusty
Ansys EmployeeHi,
Have you completely defined the hyperelastic property? as shown in the engineering data field as per below?
Please ensure all the fields are filled out. If you did, then the error messege might be due to your parameters are inconsistent with monney rivlin(5 parameters) materials. This could be due to missing or incorrect material constants or parameters that are essential for the material model to function correctly. It is also important to ensure that the experimental data collected from tests, such as a uniaxial test on an elastomer sample, is correctly imported into the Engineering Data module.
A relevant discussion you can find in the below link about neo-Hookean material.
/forum/forums/topic/elastomer-sample-neo-hookean-contain-invalid-property-data/
Hope this helps.
Thanks
Aurojyoti.
April 12, 2024 at 7:09 pm
Harry Begy
SubscriberYes, neither Mooney Rivlin 2 parameter nor the 5 parameter are working for me. all the coefficients have been curve-fitted. I have checked the material coefficients several times and the boundary conditions as well. The curve fitting seemingly gives all the required paramters as in the image below, however, the error message above " invalid property date,...elasticity is required . .." pops up. Â
- The topic ‘Mooney-Rivlin Hyperelastic Model’ is closed to new replies.
5819
