April 2, 2024 at 4:52 am
April 2, 2024 at 11:56 am
Akshay Maniyar
Ansys EmployeeHi Harry,
Can you share more details about the issue? As per the image attached, it looks like the curve fitting is not giving proper coefficients for the Mooney-Rivlin model. Do you have test data for a given material? Did you try other hyperelastic material models? Please check the below video on curve fitting and see if it helps.
Thanks,
Akshay Maniyar
April 2, 2024 at 6:28 pm
April 3, 2024 at 10:14 am
Akshay Maniyar
Are you using the material from the Ansys database or do you have any test data for the material you want to use? Also, what type of Analysis are you doing? As per the error message, it looks like you need some material property data which is not defined in your material definition.
Thanks,
Akshay Maniyar
April 3, 2024 at 3:19 pm
Harry Begy
SubscriberI am using static structure and the materials used in Ansys database.Â
April 4, 2024 at 10:21 am
April 4, 2024 at 4:09 pm
Harry Begy
SubscriberThank you . so you mean Mooney Rivlin 2 parameter does not work? I will try 5 parameter hoping to have a proper result.Â
April 11, 2024 at 1:54 pm
April 11, 2024 at 1:55 pm
April 11, 2024 at 5:48 pm
Harry Begy
SubscriberThe same error ! Any suggestions?
April 12, 2024 at 6:20 am
michelle crouch
SubscriberÂ
I’m grateful. You’re saying that the Mooney Rivlin 2 parameter isn’t functioning? I’ll attempt five parameters in the hopes of getting the right outcome candy clicker .Â
April 12, 2024 at 7:03 pm
Harry Begy
SubscriberYes, neither Mooney Rivlin 2 parameter nor the 5 parameter are working for me. all the coefficients have been curve-fitted.Â
- The topic ‘Mooney Rivlin Error’ is closed to new replies.
5674
1890
1419
