April 17, 2024 at 8:01 am
vikram chahal
SubscriberI have a fluid tank and that is partially filled by water. I want to apply a moment on the base of tank through UDF, for that i am using define CG macro. could you please help me how can i do that??
April 18, 2024 at 9:53 am
Prashanth
Ansys EmployeeHi: Can you elaborate more on applying moment on base of tank?
April 19, 2024 at 6:33 am
vikram chahal
Subscriberyes sir, i am using an UDF described below and hooking at the base of tank by taking rigid body motion,
#include "udf.h"DEFINE_PROFILE(moment_profile, thread, position){real t = real t = CURRENT_TIME;real moment = 0.0;// Apply moment in the z-direction for 2 secondsif (t <= 2.0) {moment = 5000; // Replace 'your_moment_value' with the desired moment}// Set the moment componentsreal moment_vector[ND_ND];moment_vector[0] = 0.0; // Moment in x-direction (assuming no moment in x)moment_vector[1] = 0.0; // Moment in y-direction (assuming no moment in y)moment_vector[2] = moment; // Moment in z-direction// Assign the moment componentsNV_VS(position, =, moment_vector);}
- The topic ‘moment on a tank in ansys fluent’ is closed to new replies.
