July 5, 2024 at 2:35 pm
deepesh.p.gurdasani
SubscriberSuppose I use point mass (at the C.G) instead of some body, now the CG remains same but M.I increases. Is there any way to reduce this moment of inertia and also keep CG same and using point mass?
Thanks in advance.
July 6, 2024 at 12:56 pm
deepesh.p.gurdasani
SubscriberIf anyone can guide?
Thanks in advance
July 10, 2024 at 6:53 am
Ashish Khemka
Forum ModeratorHi Deepesh,
You can input moment of inertia values for each direction when defining a Point Mass in Ansys Mechanical Application. This allows you to idealize the inertial effects from a body using a Point Mass, which can affect modal and harmonic solutions. The location of the Point Mass can be anywhere in space and can also be defined in a local coordinate system if one exists.
 https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/wb_sim/ds_point_mass.html
Ashish Khemka
- The topic ‘Moment of inertia and Centre of gravity’ is closed to new replies.
5664
1890
1419
1304
