March 18, 2024 at 3:10 pm
deepesh.p.gurdasani
SubscriberIn an assembly of few parts, I am able to see Ixx, Iyy, Izz AND C.G for each part separately but unable to see it for combined assembly when I click on 'Geometry'. Is there any way to get MOI and C.G for whole assembly combined ?
Thanks in advance
March 18, 2024 at 7:04 pm
Ankush Choudhary
Ansys EmployeeHi Deepesh,
Please check out the below video to achieve this.
https://www.youtube.com/watch?v=-UmTcGUD6lk
The other option is to create a multibody part, and then you can get the information from geometry details.
March 19, 2024 at 2:56 pm
deepesh.p.gurdasani
SubscriberThanks for the video link but to check overall C.G and M.O.I I will have to run a dummy analysis iteratively which could be time consuming, isn't it?
1) After creating multi body part, would'nt the mesh get messed up? because isnt it mainly used for getting conformal mesh similar to share topology?
2) Here actually I am not talking about splitting a single component and then moving the splitted parts into new component (which would eventually create multi body part. Here I am talking about totally two or more different parts where I want to check overall C.G and M.O.I.
Please correct me if I am wrong.
Thanks
March 19, 2024 at 3:19 pm
Ankush Choudhary
Ansys EmployeeHi Depeesh,
Yes, you have to run a dummy model to get an overall C.G. However, it is not necessary that, for a multibody part, you have to use shared topology. You can create a multibody part without shared topology as well. You can quickly create a multibody part for those parts only for which you want to check C.G. without using shared topology.
The other option is to use selection information, select the bodies for which you need information, and then use selection information to get the desired values.
March 19, 2024 at 4:45 pm
deepesh.p.gurdasani
SubscriberI selected 3 parts in spaceclaim and selected 'Move to new component'. Spaceclaim isn't anyway showing M.O.I and C.G even for that newly created component (that includes 3 parts), in mechanical also, these individual components' name now has their group name that was created in spaceclaim and even in mechanical now when I click on those same 3 parts, it doesnt show combined M.O.I and C.G.
March 19, 2024 at 4:47 pm
Ankush Choudhary
Ansys EmployeeHave you tried the selection information option?
March 19, 2024 at 4:55 pm
deepesh.p.gurdasani
SubscriberYes but selection information mainly shows C.G (Combined as well as individual) but not M.O.I.
March 19, 2024 at 5:20 pm
Ankush Choudhary
Ansys Employee-
March 21, 2024 at 5:48 pm
deepesh.p.gurdasani
SubscriberAnkush, is this feature in the latest ANSYS version? because I can see only centre of volume and principal moment (with unit of mm^5 and not kg mm^2)
March 21, 2024 at 5:59 pm
Ankush Choudhary
Please assign the density material property to the bodies in the SpaceClaim. Then you will get the correct units.
March 20, 2024 at 5:21 pm
deepesh.p.gurdasani
SubscriberThanks Ankush, will check this.
Other query I have is of, if there is a point mass (Mass and M.O.I given to it) added in 'mechanical;Â
How can point mass participate in this whole M.O.I and C.G ? Can we see point mass' C.G and M.O.I added in overall structure's M.O.I and C.G just like it shown in the image uploaded by you ?
March 21, 2024 at 12:28 am
Ankush Choudhary
Ansys EmployeeIf you want to include the point mass, then there is no other option; you have to follow the approach that is shown in the video.
- The topic ‘Moment of inertia and Centre of Gravity’ is closed to new replies.
5849
